First build, tank cutting advice
smoke_savage
Post by smoke_savage » March 22nd, 2018, 2:46 am
Hi all, I’ve decided to embark on a build, very basic knowledge so far but I’m reading as much as I can to learn.
I’ve sourced all the tools but I’m currently stuck on what cutting tool to use on a 5mm thick compressor receiver tank.
Is a plasma the only good fast option, I have access to a rental unit, are hand tools such as an angle grinder with cutting blade a complete pain in the arse? They look slow and potentially not as clean to cut?
Thanks for your time
Re: First build, tank cutting advice
Post by ajfoxy » March 22nd, 2018, 6:03 am
You can use an angle grinder with a slimmy disk (thin metal cutting disk). It is a bit slow, but hey, it's not a race it is a journey. :D
You can also use a plasma cutter. A little faster but with speed comes potential wander in the cut unless you've done it heaps of times before. 5mm should not pose a problem. Remember with plasma you'll probably get a bit of slag top and bottom of the cut, depending on your level of experience. This will need to be ground off with, yep you guessed it the afore mentioned angle grinder.
As mentioned before it is a journey building a smoker so you don't have to take the "fastest" route. Take your time, enjoy the build experience and you'll end up with a smoker that will last a long, long time.
Post by Big T » March 22nd, 2018, 8:39 pm
:yth: good advice
Post by Dirtytires » March 22nd, 2018, 10:26 pm
That is thin enough I’d just use a grinder cut-off on it. Plasma is more fun and less messy but doesn’t seem worth renting or going thru the learning curve for just a door.
