Suggest A Latch For This Cabinet????
Q-Dat
Post by Q-Dat » August 29th, 2019, 1:09 pm
20190825_121348.jpg[/attachmen[attachment=2]00g0g_c4zkDrxDugH_600x450.jpg
This is an old surgical cart that I am using as a pellet smoker. It has a latch at the top that keeps it closed, but it doesn't hold any tension. I'm going to be adding a gasket so I don't think I will need a whole lot if tension for a good seal. This is single walled stainless, the door and the cabinet are flush when closed, and the space between the door and the edge of the cabinet is about 2 inches.
Just wanted to put it out there to see what kind of latch you suggest. Thanks!
Re: Suggest A Latch For This Cabinet????
Post by Dirtytires » August 29th, 2019, 10:58 pm
Type the phrase ‘Latch action toggle clamp’ into your browser. A lot of guys swear by them and they are easy to use as well as adjustable.
Post by Big T » August 30th, 2019, 10:23 pm
