Big vertical build
Rudy
Big vertical build
Post by Rudy » March 27th, 2019, 10:06 am
Hi, new to the forum. I've been smoking for about a year so far. I bought a OK Joe offset on sale at Lowes, and modified it. Has been going strong, and produced a lot of tasty treats! I smoke 2-4 times a week. Modifications include a NG burner for the main heat source, and a pot above it for smoking wood (chips, chunks, small rounds, and pellets). I made my own tuning plates out of 1/2" thick flat bar. Works well, but my only complaint is that I can't get over 250F. It's rock steady 250F summer, winter, wind or calm. Normally this is what everyone looks to have. But, I want to be able to crank it up for certain things.
So, a few months ago I bought a steel hot water holding tank at an auction. It's 4 feet in diameter and 6 feet long. It weighs almost 1000lbs by itself, and I figure wall thickness is about 1/4" - 3/8". There's a big access hatch at one end. My plan is to stand it up, cut about 2 feet out of the center section, put in an 80,000 btu NG burner from Tejas smokers, with a cast iron pan above it for wood. The inspiration for this build comes from looking at kamados, but not being able to justify the $$$$ to get one.
There's quite a few other ideas for some of the finer details, but I'll share them as I go.
Re: Big vertical build
Post by Chromeski » March 27th, 2019, 3:21 pm
Sounds like your ok Joe is running great. I would keep that thing the way it is since it holds 250F so well. I think you just need a separate grill/ santa maria setup for cooking hot.
The new tank has a ton of potential just be careful using gas burners. I know your other build has been successful so far, just make sure you have all the necessary safety measures in place. Scary stuff if you get a tank like that full of unburned gas
Rudy
Post by Rudy » March 27th, 2019, 4:12 pm
Safety is important for sure. I had the OKJ blow out once or twice. I just open all the doors for a minute and relight.
There's a bunch of occasions where the OKJ is too small. The normal once a week for work is only for 3 guys, so it's a good size for that. But, we regularly have decent size parties, and depending what it is that's on the grill, it can fill up quick. The idea is to build a grill/smoker that is more capable, and can do more. I plan to build a griddle and will have a pizza stone setup, in addition to having lots of grilling space. These are things that the OKJ is not capable of. I plan to still keep it for smaller cooks, like the once a week for the boys at work. It's nice to have options.
Post by Dirtytires » March 28th, 2019, 12:06 am
You did grill/smoker.
Remember, to do it right, you need to build a grill——and a smoker.
