Vertical Stainless Santa Maria Combo Build
addison363
Post by addison363 » June 6th, 2017, 10:13 pm
Hello all,
The journey begins! I have a stainless steel hull of a test stand that has been sitting in my garage for far too long. It is essentially a 6 ft server cabinet attached to a drain table. I'm starting the smoker portion this weekend. Pictures document starting condition. Steel is ordered! Addison
If it isn't broken, take it apart and fix it!
Re: Vertical Stainless Santa Maria Combo Build
Post by Big T » June 6th, 2017, 10:29 pm
That should be a sweet build. :kewl:
Post by ajfoxy » June 7th, 2017, 2:03 am
Welcome.
That is definitely going to be a very interesting build. I look forward to see how it all unfolds.
Post by Squiggle » June 7th, 2017, 2:21 am
:welcome: should be a very interesting build. :kewl:
Post by Rodcrafter » June 7th, 2017, 5:58 am
:welcome:
Welcome to the crew!
If we can help just ask.
addison363
Post by addison363 » June 7th, 2017, 11:45 am
This is a rough sketch of where I hope this project is headed...but the devil is in the details. I borrowed shamelessly, the pizza oven feature idea, from Pete M. Pure genius! The magic will be to find just the right burner. I will want good control of the entire cooking chamber which is 28,643 cu. in. (temperature target 225 as a smoker and 400 as a big A$$ oven) and also be able to put in temporary ceiling to make a pizza cooking chamber of 5,771 cu. in. and crank that smaller space up to 650 degree F. I have my eye on a LP 2 piece burner from Tejas (LPCAST10-2) that puts out 100,000 BTU but looks like flame can go also really low. Any thoughts on Low Pressure vs High Pressure?
Right now I'm trying to work out the vertical spacing. I'm thinking of putting 4.5 inches between shelf supports, but how many inches above the top of the charcoal basket do I place the bottom of the water/sand pan? Is it just clearance for easy refill or is there more science to it? -- Addison
addison363
Post by addison363 » June 20th, 2017, 9:25 pm
Progress update:
1. Back cover cut, drilled and attached.
2. Ceiling cut out for server rails, insulated and attached.
3. Back cut, drilled, insulated and attached.
Here are latest pics. -- Addison
Post by Big T » June 20th, 2017, 9:43 pm
Post by ajfoxy » June 20th, 2017, 11:09 pm
Looking like it is all coming together. Can't wait to see it in action.
Post by Squiggle » June 23rd, 2017, 8:24 am
addison363
Post by addison363 » July 10th, 2017, 3:08 pm
Thanks for all of the encouragement! Good progress continues. Ceiling (except for whole hog hook), back and right sides are done. Left side is in progress...Next up is to finish plumbing the air inlet and cutting in thermocouple access tube to the instrumentation cabinet. I'll post more pics soon.
I've not got a good idea for cooking grates. I bought some 3/4" x 13 GA. MILD STEEL A36 FLATTENED EXPANDED SHEET, but don't weld (...yet). Maybe on my next smoker!
Question: I'm thinking of just cutting it to width (17.5 inches) and then bending down the front edge to create a lip and bending up the back edge. Total cooking surface depth would be 22 inches. They would nest nice for storage and I think the 2 bends would add side to side rigidity and I only have to span a 17.5 span width. I've got pretty full shelf supports and would only be cantilevering 2 inches off the front and the back. Any concerns with this plan? Better ideas for a "No Weld Cooking Grate Design"?
Thanks in advance for the replies. Addison
Post by Rodcrafter » July 12th, 2017, 7:05 am
Sounds like a great option!
Post by Squiggle » July 13th, 2017, 9:21 pm
:LG: very nice work dude, well done! :kewl:
addison363
Post by addison363 » July 18th, 2017, 12:35 pm
I haven't posted pics in a while. Here are a few to start catching you up. More to come.
Post by Rodcrafter » July 18th, 2017, 12:37 pm
Sweet!
Post by Big T » July 18th, 2017, 5:46 pm
:kewl:
Post by temurf » July 18th, 2017, 9:42 pm
addison363
Post by addison363 » July 20th, 2017, 11:32 am
Next batch of pictures! She is coming along!
addison363
Post by addison363 » July 21st, 2017, 6:28 am
Grates and burner cut-in completed last night. Making burner brackets today. Installing burner and drip edges this weekend and then she should be ready for a good clean and burn.
Post by Big T » July 21st, 2017, 6:05 pm
Post by temurf » July 21st, 2017, 6:09 pm
:kewl:
Looking good.
You'll be posting Q-View before you know it.
Post by ajfoxy » July 22nd, 2017, 3:10 am
That is definitely looking great. Good strong work, well done! :points:
Post by Squiggle » July 23rd, 2017, 4:06 am
Looks awesome dude! :kewl:
addison363
Post by addison363 » July 24th, 2017, 6:24 pm
Well it was bound to happen...I hit a snag. I got the burners cut in and mounted. Got all the paint pen removed and gave the inside a nice bath with mineral spirits followed by soap and water. I rolled it out into the drive way, hooked up the propane and prepared for the first burn. Pilot and burners lit just fine but wouldn't stay lit for very long. At first I thought it was just the breezy day we were having today. Now I think it is definitely an air problem. I just watched the burners with the door open for 5 minutes. I then closed the door and burners and pilot went out in less than 2 minutes! At least my safety valve has gotten a good test! I couldn't smell even a hint of propane gas when I opened the door after pilot and burners went out.
The exhaust is a 2" x 7.5" rectangular hole in the top of right side wall with a slider damper over the top on the outside. It was fully open.
Inlet air is 2 ways. The first is a 2" pipe and ball valve arrangement that was fully open during the test. The second is the oversize cut out and burner mounting. 7" x 13.25" rectangle opening in bottom with (2) 6" diameter burners below. Burners are mounted under the unit with top of burners being flush with the floor.
My hunch is that somehow my exhaust is not working like I expected and she is filling up with combustion gasses that are extinguishing the flame just haven't figured out how to confirm or have any ideas to fix it. Any troubleshooting advice? -- Addison
addison363
Post by addison363 » July 24th, 2017, 6:36 pm
