T-Shaped UDS Style Smoker/Charcoal Grill
Fishless Mickey
Post by Fishless Mickey » May 16th, 2014, 8:22 am
Howdy Smokerbuilders. I am getting ready to start a new project for my Mom. Her requested parameters are: Light and easy for her to handle, smoker and a charcoal grill, and uses very little charcoal/wood. I have attached a rough sketch and pics of the tanks. The tanks are 16"x24"(21gallons)CC, & 13"x24"(13.5gallons)FB. Both are 1/8" steel i think. Not included in the sketch are: grease drain/air inlet piping and valve at the low point of the baffle "v", latches and 1/2"x1/8" angle iron to seal the CC door. Depending on weight and how difficult it is, i may add a counter balance to the CC door. I am open to any suggestions and will post updates as the project progresses.
Don't hate me because I'm pretty
SmokinFF
Re: T-Shaped UDS Style Smoker/Charcoal Grill
Post by SmokinFF » May 16th, 2014, 9:25 am
Get to building!! I wanna see this come together so I can steal the idea. :beer:
Fishless Mickey
Post by Fishless Mickey » May 16th, 2014, 6:01 pm
Having some difficulty uploading todays progress. Here goes again....
Fishless Mickey
Post by Fishless Mickey » May 16th, 2014, 6:04 pm
Ah well.... Sideways is better than no pics at all.
Fishless Mickey
Post by Fishless Mickey » May 16th, 2014, 6:15 pm
Amazing welding ability.... :BS:
Post by Puff » May 16th, 2014, 8:45 pm
I guess that's a well pressure tank? Very nice cutting out those holes. What will you being doing to stabilize the unit?
Post by Gizmo » May 17th, 2014, 5:37 am
That looks like it'll work! :kewl:
Fishless Mickey
Post by Fishless Mickey » May 17th, 2014, 7:09 am
The grill will be mounted in a 3/4" or 1" square tubing frame. I'll do my best to keep it light and manageable without sacrificing durability. I have an old kitchen table-top to make some nice wrap around panels out of. The only real weight will be in the base and wheel mounts to keep it from being too top heavy.
Clover Ridge Smokers
Title: Driven By Passion
Post by Clover Ridge Smokers » May 20th, 2014, 8:26 am
:LG: :LG:
Fishless Mickey
Post by Fishless Mickey » June 20th, 2014, 7:36 am
So...... Mom said the grill wasn't big enough for her. I had to Biggy-Size it. Thankfully it was plenty early in the process. Ill finish the small one at a later date. Here are the updates. I have hinges and a frame on it too now but will wait to post next when I am ready to paint.
Post by The Czar » June 20th, 2014, 9:10 am
Post by Rodcrafter » June 20th, 2014, 10:19 am
Nice work
SmokinFF
Post by SmokinFF » June 20th, 2014, 9:38 pm
That's a nifty little rig. :LG:
Fishless Mickey
Post by Fishless Mickey » July 1st, 2014, 1:47 pm
Nearly finished. I just have the wrap around shelf, 1 1/2" air control ball valve, CC door seal + thermometer and she's ready for delivery! I'll post the final pics soon. Test burn surprised me. The center was colder by 8 degrees than the side of the main grate. I may have put too much angle in the fire baffle.
Post by Rodcrafter » July 1st, 2014, 3:37 pm
Nice, we all know when Moms happy everybody's happy
Fishless Mickey
Post by Fishless Mickey » July 2nd, 2014, 2:57 pm
All done! The wood shelf will only likely last a year or so. I gave it three coats of clear rustoleum exterior. I went with high temp rtv for the cc gasket. No latch. The weight of the kid holds it closed firmly. I may add a latch to it down the road when I change her shelf out for Hardie Board.
Post by Rodcrafter » July 2nd, 2014, 7:58 pm
That will make Mom happy for sure
Post by The Czar » July 2nd, 2014, 8:31 pm
Nice....me likey
Post by Big T » July 2nd, 2014, 8:52 pm
Sweet !!
Fishless Mickey
Post by Fishless Mickey » July 3rd, 2014, 6:37 am
Haha typo. Although she is raising a bunch of kids, I don't think she will need to use one for a CC door weight. Thanks fellas. She cooked us some BBQ chicken upon delivery. The charcoal grate got plenty of oxygen with the air valve open. CC got up to 480degrees with the CC lid closed. Neat little set up. I think I'll make me one now. After putting the word out there, I ended up with 6-7 small tanks to work on. My wife said no more tanks a couple tanks ago :oopssign:
Post by Gizmo » July 3rd, 2014, 7:00 am
That's a NICE looking rig there! :kewl:
If you want to fix the temp variance drill a 1" hole toward the center of the baffle plate and tap it for pipe thread. Screw a "close" union into them to prevent grease from going down into the fire. That will let just a little of the heat rise directly to the center of the grate and should even out the temp immediately. Start with just one at first then "tune it with more holes if needed. jm2cw …. :D
Fishless Mickey
Post by Fishless Mickey » July 21st, 2014, 1:30 pm
I think the temperature issue was thermometer related. I delivered the grill to Mom on July 3rd. She said she hasn't used her kitchen stove since then.
Post by Gizmo » July 22nd, 2014, 6:34 am
Well we all know that if MAMA's happy - EVERYBODY's happy! :D
