Insulation question
FOMOGO
Insulation question
Post by FOMOGO » September 25th, 2015, 8:04 am
I have been a lurker here for a while and have learned a lot of good information. Now I have a question concerning insulation. I had a commercial refrigerator unit fall in my lap. After researching on the forums I have learned about the foam insulation problem. Is there anyway to figure out if this unit has foam insulation without tearing it apart? It is a nice unit and I hate to make a mess of it.
Second question. The racks are plastic coated. Will this be an issue with temps in the 225 to 275 range? I can make new racks but these are nice and fit already.
Final question. Any suggestions on a heat unit. I have 2 thoughts. A pellet cooker unit on each side or a cook top type burner inside with a deflector / grease pan above it.
Any and all input will be much appreciated.
Many thanks for sharing your knowledge.
FOMOGO
Re: Insulation question
Post by Rodcrafter » September 25th, 2015, 10:07 am
I never have made one of these but I can speak to the coating on the shelves. Plastic will not be ok in any cooking chamber. As for the insulation, if I was building it I would remove whatever is there and put the type I want so I know it is sound. As for the heat source, the pellet pooper is a good idea. You may need to add some cold air inlets also, as vertical cookers don't need a lot of heat so if it is too efficient the fire will go out on the pellet drive. Personally I would go with a charcoal basket instead, run it like an UDS.
Jm2cw
FOMOGO
Post by FOMOGO » September 25th, 2015, 9:05 pm
Rodcrafter, thanks for the reply. I am leaning towards the pellet cooker units as this will be used inside of a restaurant. I don't want to tear this thing apart if I don't have to but I can if it is necessary. I wasn't real fond of the plastic rack coating but wasn't sure if anybody had any experience with it. I will just go ahead and build racks for it and make them slide out and have multiple positions. Just trying to help a friend out that has a great little BBQ restaurant but a POS little cooker. Thought this might be a simple solution for him to have an indoor smoker.
forty_creek
Title: 40 Ways 2 Kansas
Post by forty_creek » September 25th, 2015, 11:13 pm
Ditto RC!
He is the MAN, the MYTH, the LEGEND
Drankin, Smokin and Dreamin
DRANKIN, SMOKIN and DREAMIN
Post by Rodcrafter » September 26th, 2015, 11:58 am
FC you're too much.
SweetSmokinBBQ
Post by SweetSmokinBBQ » November 13th, 2015, 9:02 am
I am getting ready to convert a commercial fridge myself and I have decided to go with a gravity feed burner. This system will burn 14-18 hours on one 20lb bag of lump. I plan on attaching a bbq guru to it then I should be able to walk away and let it cook. The only downside I have seen and tasted from pellets is that you don't get much smoke. That is the reason that I decided to go with a gravity flow.
