Freezer build I need some help
Cohoho
Post by Cohoho » March 18th, 2014, 2:02 pm
I have a stainless steel blast chiller it is stainless inside and out my problem is it has polyurothaine insolation I want to know if I line the inside with rock wool insolation then seal it in with rock board or aluminum sheeting would that insulate it enough so I do not have to take the unit apart and remove the polyurothain insolation ?? I really do not want to take this thing apart but I want to know it is safe to cook in any information is welcome thanks.
Re: Freezer build I need some help
Post by Frank_Cox » March 19th, 2014, 8:33 am
you would prolly be fine to line it with roxul insulation and then skin the inside but the inside would need to be welded solid so it does not leak. I seen a pepsi vending machine done this way once and it worked fine but it smelled bad on the outside still.
Cohoho
Post by Cohoho » March 19th, 2014, 11:22 am
Think I'm leaning towards just doin cold smoke I think it is going to be next to impossible to take this thing apart. If I start ripping it apart to remove all the insolation I think I will destroy it and it is too nice of a unit to just destroy so I think a cold smoker is the way to go for now till I figure how to replace the insolation without wrecking it. Now as for being a cold smoker the insolation should be fine as is anyone disagree with that or I'm I good to go??
Post by Puff » March 19th, 2014, 10:08 pm
My cold smoking has never hit 90 degrees inside my whiskey barrel using a pellet tray for about 5 hours. When outdoor temps are below 45 it does not see 70. These temps seem to be easily within safe regular summer ambient temps. And the box insulation should not react. Some cold smoking may be defined as below 140 that I would not know much about. You might even wish to try an outboard smoke generator with the smoke piped in from 2-4 feet away if you're really concerned. This method might qualify numerous other vessels to be used as cold smokers.
Post by Frank_Cox » March 20th, 2014, 8:13 am
Interesting thought here.....
In some areas of the country it is hard to cold smoke in the summer because it's too hot. wonder if something like this might work! put it on the inside of the smoker and turn it on.... if it was built out of steel....
Post by The Czar » March 20th, 2014, 1:35 pm
WTF kinda of hippie crap is that ?
SmokinFF
Post by SmokinFF » March 20th, 2014, 3:29 pm
Looks like a custom Smokerbuilder air conditioner to me. :beer:
Post by Gizmo » March 21st, 2014, 4:26 am
Fill it with water and you got a whole-house humidifier for a single-wide… just sayin' :D
bjackbbq
Post by bjackbbq » March 23rd, 2014, 1:48 pm
Frank_Cox wrote:you would prolly be fine to line it with roxul insulation and then skin the inside but the inside would need to be welded solid so it does not leak. I seen a pepsi vending machine done this way once and it worked fine but it smelled bad on the outside still.
Frank, would it smell bad because of the Roxul? I am getting ready to build a Pellet Smoker and was looking into using Roxul.
Sent from my SCH-I545 using Tapatalk
SmokinFF
Post by SmokinFF » March 23rd, 2014, 3:08 pm
The smell would be from the existing foam insulation. Just my $.02. :beer:
redruff
Post by redruff » March 23rd, 2014, 10:01 pm
You don't want to line it with aluminum. Acids from rubs, food etc. can react with aluminum.
Aluminum oxide isn't something you want to eat.
Line it with stainless if you are going to skin it.
Post by Puff » March 23rd, 2014, 11:02 pm
By the way, your external smoke generator would work well. It will create the smoke, air flow and keep heat away from the smoke vessel. Don't let it blow hard but trial and error will help decide
Post by Rodcrafter » March 24th, 2014, 6:18 am
You don't have to use expensive metals the steel you use won't rust. Once you treat it with cooking spray and begin using it it will collect a thin coat of goodness and rust will no longer be a part of the process.
Margaret8
Post by Margaret8 » September 24th, 2014, 6:25 am
Certain parts of my refrigerator got corroded since its been in use since ages. It was causing a squeaking sound everytime I opened and closed the freezer. I consulted a profesional powder coating service for rescue. They examined the internal parts and it was finally saved from damage.
dancalvin12
Post by dancalvin12 » September 18th, 2015, 5:17 am
no i don't think so that Roxul have that much weird smell, have you made it?? share your pictures with us
