New GF Double Pan started in Virginia
dgrimm
Post by dgrimm » July 18th, 2019, 10:15 am
:biggrillin:
dgrimm
Re: New GF Double Pan started in Virginia
Post by dgrimm » July 18th, 2019, 10:18 am
After talking to Frank about my best option, he suggested the Double Pan Gravity Feed. Looking forward to this project!!
Post by Dirtytires » July 18th, 2019, 10:32 am
Lot of those built around here....I’m sure everyone will be here to answer question as they come up. Please be sure to share your progress and welcome to the board.
dgrimm
Post by dgrimm » July 19th, 2019, 7:28 pm
Currently sourcing metal, couple of questions. Has anybody that has built a GF screwed the outer skin on? I decided to go with 1/8” tubing thickness and sheeting as it’s easier to weld, as I have a stick welder.
Post by Big T » July 19th, 2019, 7:34 pm
There have been a few over the years that have been screwed or riveted in place.
Post by Dirtytires » July 19th, 2019, 11:48 pm
Probably no issues with performance.
I might be concerned with moisture getting in to the insulation and rusting it from the inside. Welded seams tend to keep rainwater out better.
dgrimm
Post by dgrimm » July 22nd, 2019, 9:52 am
I concur Dirtytires, will be welding seams, also maybe drill holes in skin and plug weld to frame.
Post by ajfoxy » July 22nd, 2019, 4:43 pm
On my DP I made the "lid" a tad larger and bent over a lip (fortunately I have a pan brake), that took care of the water ingress. I did weld all the other seams though. Lots of warpage. So go slow. If you do decide to bolt/screw them together just use high heat silicon in the seams.
