Sawtooth cutting
Tipps
Sawtooth cutting
Post by Tipps » August 21st, 2018, 9:45 pm
I’ve seen just a couple pics of a sawtooth intake on fireboxes, and I think that may work best for mine.
What’s the easiest way to cut the notches that are rounded if I don’t have a plasma cutter? Do you guys that do this just use a grinder? Thanks
Re: Sawtooth cutting
Post by ajfoxy » August 21st, 2018, 11:11 pm
Not sure how it should be done, but if I were doing it without a plasma cutter I'd drill a hole at the peaks and valleys of the saw tooth and use an angle grinder and slimmy disk to cut between. Then maybe tart it up with a file etc.
Tipps
Post by Tipps » August 21st, 2018, 11:22 pm
Yes that’s what I’ll do! Don’t know why that didn’t cross my mind, thank you.
Post by Dirtytires » August 22nd, 2018, 12:13 pm
Not saying it can’t be done but I would find a friend with plasma or I’d change the design. Cutting a radius with a grinder is not something I would do when there are other options out there.
Tipps
Post by Tipps » August 24th, 2018, 11:56 am
I was thinking that the drilled holes on both ends of the notches would take care of the rounded parts of the notch/tooth, and all that would be left to cut with the grinder would be straight cuts to remove the metal between the drilled holes. nobody I know has a plasma, i'll buy one some day. I've already cut the opening for the intake so am going to proceed the best I can.
AndrewPalmer71
Title: SmokinAddict
Post by AndrewPalmer71 » August 24th, 2018, 5:06 pm
Awesome! Get it done brother, I'm interested to see how it works out.
Tipps
Post by Tipps » August 29th, 2018, 11:50 am
Got it notched and installed, and it works great. I just drilled a hole every inch in the middle of the flat bar that would be used to lift the opening cover plate, and then cut the remaining metal with a grinder. Smoothed them out with a Dremel. not perfect saw teeth, but they hold and now I have an adjustable vent that's centered, and at fully open it's a bit larger than recommended calculator size.
Tipps
Post by Tipps » August 29th, 2018, 11:51 am
AndrewPalmer71
Title: SmokinAddict
Post by AndrewPalmer71 » August 29th, 2018, 1:26 pm
Looks good! Always more than one way to get it done.
Post by Big T » August 29th, 2018, 5:25 pm
Post by ajfoxy » August 29th, 2018, 10:14 pm
Nice. :kewl:
Post by Rodcrafter » August 31st, 2018, 3:27 pm
Heck yeah
