3 mm is thin for the cook chamber. Ideally you would want it 5-6 mm.Izek66 wrote:Hello!
Thanks for the support and advice!
The wall thickness of CC is 3 mm. Is it small or good? Thickness FB 9 mm...
9 mm is great for the firebox.
Your firebox doesn't need to be 9mm. Many here are 1/2 inch which is in the 6mm range.Izek66 wrote:Hello! I can't make the walls of CC thick. The trailer can only 550 kg. This is our law for private trailers.
I meant 1/4"...good catch ajf!ajfoxy wrote:Erm mp4.... 1/2 is 12mm not 6mm. 1/4 is 6mm.
But if you already have 3mm cook chamber that's what its going to have to be.
