Shelf Frame - Notch and Bend Angle - Has anyone done this?
Cole
Post by Cole » February 7th, 2018, 6:58 pm
Hello Everyone,
Wondering if anyone has made a shelf frame by notching a length of angle and then bending to make the rectangular frame? See test below.
Re: Shelf Frame - Notch and Bend Angle - Has anyone done this?
Post by Big T » February 7th, 2018, 7:04 pm
I haven't used this technique for building grates but I have used it many times for other projects. It makes for a clean edge and a good looking grate as long as all of the notches are in the correct place and it remains square.
Post by ajfoxy » February 8th, 2018, 1:51 am
Measure twice, cut three times... :D
Post by Dirtytires » February 8th, 2018, 11:45 am
It works....have to decide if all the triangle cuts are easier than grinding a welded edge smooth.
Both are fine.
Post by Big T » February 8th, 2018, 8:54 pm
ajfoxy wrote::yth:
Haha Story of my life. ~x(
Post by Weldun » February 8th, 2018, 9:31 pm
That's why I always cut long pieces first that way I can salvage short ones from them Big T
Post by Big T » February 8th, 2018, 11:39 pm
Weldun wrote:That's why I always cut long pieces first that way I can salvage short ones from them Big T
Same here, I figure if I can make it shorter pretty easy but if I need to make it longer again it takes some work.
Cole
Post by Cole » February 9th, 2018, 11:41 am
Nothing like metal work! A little Oh Crap! Cut, grind, cut, Grind some more, Weld and weld and Grind! No one will ever know unless you tell!
Post by Rodcrafter » February 11th, 2018, 7:32 pm
I don’t do mine that way I think it may be it takes too much thought.
Chukknob
Post by Chukknob » November 19th, 2018, 2:06 pm
How does this measure out. If your grate is 48 wide by 22, do you simply measure those points twice and then cut? So 22, 48, 22, 48?
Post by Dirtytires » November 19th, 2018, 6:10 pm
You will loose a little legnth on each bend but, yes, the center of the notch is the outside of each corner.
