How the flatten .250 steel sheet
Tips and tricks for everything related to finishing your smoker.
Heatermeter builder
Post by Heatermeter builder » November 21st, 2017, 3:38 pm
I'm making the double pan gravity and I picked up my .250 inch precut material and when I got home I realized it had a bow. I could have probably been ok and straighten it as I welded it but when three pieces are bowing outward and one piece bowing inward, it made it difficult.
What would be the easiest way to straighten them out. As of now, I have them clamped down and I am putting pressure on the bowed area and they are straight. Will keep them that way overnight. Hopefully that will work enough.
If you would like information about building your own heatermeter or having someone build one for you, feel free to ask any questions you may have.
Bricklayer2
Title: Masonry Contractor
Re: How the flatten .250 steel sheet
Post by Bricklayer2 » November 21st, 2017, 7:53 pm
I have spot heated with a torch to take bows out of steel! But for me, I have about a 50/50 chance getting the result I want :ympray: . I bet some steel fabricators here can give better advice but heat will work. :kewl:
Weldun
Title: I'm no expert
Post by Weldun » November 21st, 2017, 8:43 pm
Try placing it on a bench with the bow up and block the ends up on wood blocks and draw the center down with a clamp a bit past what you want and give it a smack with a hammer, the shock from the hammer will usually do the trick. It may take a little trial and error but I prefer cold straightening when possible.
Heatermeter builder
Post by Heatermeter builder » November 21st, 2017, 8:45 pm
Thanks, I have it clamped up now will get my big hammer from work, and wack it a death, lol
Weldun
Post by Weldun » November 21st, 2017, 9:29 pm
Heatermeter builder wrote:Thanks, I have it clamped up now will get my big hammer from work, and wack it a death, lol
Remember little at a time
Post by ajfoxy » November 22nd, 2017, 4:03 am
:yth: Small steps. What parts of the smoker are the pieces for? In other words will it show/matter they have a slight bow? Presuming it is slight.
Post by Rodcrafter » November 26th, 2017, 9:36 pm
Make the bow go to the outside and move on. lol
Return to “Fabrication How to's”
