Cutting 48" Door from propane tank
jamiewa82
Post by jamiewa82 » June 26th, 2017, 9:44 pm
Hi,
I am in the phase of cutting my door from a 200 gallon propane tank. The door is 48" long that I am cutting out. My question is should I weld the hinges before I cut the door all the way. I bought 3 - 3" bullet hinges. If the answer is yes than how do I weld the strap metal afterwards and what thickness should the strap metal be? Any help or input would be appreciated.
Re: Cutting 48
Post by Big T » June 26th, 2017, 11:08 pm
Welcome aboard!! I would cut the door completely out first and make sure it doesn't warp. That way you can straighten it up if it does. I use 1/8''x1 1/2 or 2'', I have used 1/4''x2'' but it's a little harder to bend it.
jamiewa82
Re: Cutting 48" Door from propane tank
Post by jamiewa82 » June 26th, 2017, 11:22 pm
Thanks for the help and warm welcome. If it does warp what is the best way to combat that?
Re: Cutting 48
Post by Squiggle » June 27th, 2017, 1:53 am
:welcome:
Re: Cutting 48
Post by ajfoxy » June 27th, 2017, 3:32 am
:welcome:
If it does warp. Some chain, a jack and have at it.
Re: Cutting 48
Post by Rodcrafter » June 27th, 2017, 7:36 am
:welcome:
Welcome to the crew!
I like to cut mine out first, then flange it, then weld the hinges to either the flange using bullet hinges or make my own and weld them to the door.
I have to ask "3 inch" is that the total length? or is that each piece of the hinge? I asked the question because this is a very heavy door you're making, and if you put an counterweight on it that would even be more weight. Those hinges are much stronger vertically than laying flat. I just want you to like what you wind up with when you're done.
Some folks around here think I make stuff too heavy so you can totally disregard my question if you want.
jamiewa82
Post by jamiewa82 » June 27th, 2017, 8:27 am
Thanks for the welcoming! Rodcrafter, I bought some plans from smoker builder and these are what were spec'd. There are 3 of them though. Is there any tricks to forming the strap metal around the door? Ajfoxy thanks for tip!
Re: Cutting 48
Post by Rodcrafter » June 27th, 2017, 10:17 am
You can use the tank as a mold of sorts tack the end of the strap to the tank and just pull down on it as if your going all the way around it cut the tack and lay it on you lid and weld it.
Re: Cutting 48
Post by temurf » June 27th, 2017, 6:24 pm
:welcome:
Hope you don't need it but here is a link to a post by Big T about fixing a sprung door.
viewtopic.php?f=148&t=3344&p=80081&hili ... oor#p80081
Kcd2016
Re: Cutting 48
Post by Kcd2016 » June 28th, 2017, 9:37 am
jamiewa82 wrote:Thanks for the help and warm welcome. If it does warp what is the best way to combat that?
Here's what I did:
Re: Cutting 48
Post by Squiggle » July 2nd, 2017, 6:55 am
:LG: nice work! :kewl:
Post by Rodcrafter » July 2nd, 2017, 8:35 pm
Who said it warped, great work
