Shelf Frame - Notch and Bend Angle - Has anyone done this?
- SmokerBuilder Addict
- BBQ Comp Team Name: Not competing yet, Family and Friends!
Hello Everyone,
Wondering if anyone has made a shelf frame by notching a length of angle and then bending to make the rectangular frame? See test below.
Re: Shelf Frame - Notch and Bend Angle - Has anyone done this?
I haven't used this technique for building grates but I have used it many times for other projects. It makes for a clean edge and a good looking grate as long as all of the notches are in the correct place and it remains square.
- ajfoxy
- Title: Neophyte Smoker Bldr
Measure twice, cut three times...
It works....have to decide if all the triangle cuts are easier than grinding a welded edge smooth.
Both are fine.
Both are fine.
ajfoxy wrote:![]()
Haha Story of my life.
- Weldun
- Title: I'm no expert
That's why I always cut long pieces first that way I can salvage short ones from them Big T
Same here, I figure if I can make it shorter pretty easy but if I need to make it longer again it takes some work.Weldun wrote:That's why I always cut long pieces first that way I can salvage short ones from them Big T
Nothing like metal work! A little Oh Crap! Cut, grind, cut, Grind some more, Weld and weld and Grind! No one will ever know unless you tell!Big T wrote:Same here, I figure if I can make it shorter pretty easy but if I need to make it longer again it takes some work.Weldun wrote:That's why I always cut long pieces first that way I can salvage short ones from them Big T
I don’t do mine that way I think it may be it takes too much thought.
- Wants More tools
How does this measure out. If your grate is 48 wide by 22, do you simply measure those points twice and then cut? So 22, 48, 22, 48?
You will loose a little legnth on each bend but, yes, the center of the notch is the outside of each corner.
