Beginner with smoker building questions..
Forum How-to's, questions or issues and the site slang database.
jlvasquez89
Post by jlvasquez89 » July 20th, 2018, 7:02 pm
Hello everybody. My name is Jeff. I'm new to the site. A little while back a bought a used water tank I had seen for sale on Facebook. I had planned on making it into a smoker at when I was on my way out to pick it up. Once I saw the size in person, I thought it would be cool to close up the middle and have a charcoal grill on one side and a reverse flow smoker on the other. The main question I have right now, is will it be difficult to maintain the correct heat on the smoker side if its split up like that. If not, how big of a firebox should I build for it? I'm sure this is a stupid question, like I said I'm new to it all. Any tips and recommendations would be appreciated. Thank you.
Re: Beginner with smoker building questions..
Post by Big T » July 20th, 2018, 7:50 pm
Welcome aboard! The design that you mentioned isn't really ideal because the FB needs to be mounted low on the cook chamber for everything to work right. You could put a false double wall in the middle and add a FB on one end for a RF and build a charcoal grill on the other end. You can plug you dimensions into the pit calculator and it'll figure your FB size and other dimensions.
jlvasquez89
Post by jlvasquez89 » July 20th, 2018, 9:05 pm
I was planning on building the firebox low one one end. Thanks for the info. I'll have to check out the calculator so I can draw it up.
Post by Dirtytires » July 20th, 2018, 9:49 pm
So, I am picturing a normal reverse flo smoker using half the pipe and then a charcoal grill using the other half of the same pipe. Right?
No reason why it won’t work but a few things to consider. First, a hot charcoal grill (in use) on one side is totally going to play games with your temp co troll on the smoker. It would be like having 2 heat sources for a smoker and I would think challenging to control. Second is size/weight. Assuming it will be mobile, I see a lot of extra weight to move around then only 1 side is needed.
Post by Big T » July 20th, 2018, 10:14 pm
A sketch would definitely help us to see what you have in mind. I remember a build that was similar to this a few years ago that a member built and I believe that he put a double wall between the smoker CC and the grill so that he didn't have the radiant heat from the grill causing temperature issues in the smoker side. I know that TQ builds a 36'' grill directly on the end of some of his builds and the guys that use them love them so it will work if done correctly.
Post by Chromeski » July 27th, 2018, 3:55 am
Options come to mind: cut completely In half and make two separate units.
Double wall the divider with insulation so the effect of two heat sources is not as extreme.
Just go big and make it one large reverse flow unit.
With a job this large I'd think pretty serious about what you will actually use it for. Do you need a separate side.
Post by Rodcrafter » July 28th, 2018, 10:51 am
Welcome to the crew!
Given enough info for what you want to build we can help you spend your money. LoL
Mule rider
Post by Mule rider » November 29th, 2018, 11:55 pm
If I am hearing you right you want to cut that tank in half and make a smoker and a griller with it? Cutting it in half you would have very low cooking chamber.
Post by ajfoxy » November 30th, 2018, 3:45 am
Welcome.
Return to “Welcome!”
