Spacing between the smoker and the Rib warmer
Neckbone35
Post by Neckbone35 » May 19th, 2017, 12:41 pm
How much space, if any is required to prevent to much radiant heat?
Re: Spacing between the smoker and the Rib warmer
Post by Big T » May 19th, 2017, 4:50 pm
Usually there's not a gap between them if you aren't adding a baffle from the FB. You will need to have some vents in the WC so you can let some heat out to regulate the temperature.
Neckbone35
Post by Neckbone35 » May 19th, 2017, 4:55 pm
WC meaning the warming Chamber?
Neckbone35
Post by Neckbone35 » May 19th, 2017, 4:57 pm
Would those vents exit in to the Cook Chamber or directly outside?
Post by Big T » May 19th, 2017, 5:05 pm
Yes sir the warming chamber and they would exit outside so you can dump some heat if you need to.
Neckbone35
Post by Neckbone35 » May 19th, 2017, 5:11 pm
Awesome!!!! How would a firebox baffle work. I truly appreciate the help your giving me.
Post by Big T » May 19th, 2017, 5:50 pm
It's just an opening (round or square) in the top of the FB with a slide over it so it can be opened or closed from outside the pit. If I was putting a WC on my smoker I would have an opening from the CC and the FB and the cooking options would be endless. Check out Mack, it's at the top of the RF section and there's a lot of good pictures in there.
Neckbone35
Post by Neckbone35 » May 19th, 2017, 7:07 pm
Awesome. Thank you again. I'll be starting construction of the smoker this weekend.
Post by Rodcrafter » May 20th, 2017, 6:23 am
Welcome to the crew!
It looks like you are headed the right way.
This is the control between my FB and WC/VC when you do this the WC can also be a Vertical Cabinet because you can cook in it. My FB is 1/2" plate then I have 2" of 2000* insulation then the WC bottom. So only the heat I want goes through this opening. If I leave it closed the temperature never gets over 140* in the WC.
Just ideas not required.
