Thermometer port.
12ring
Thermometer port.
Post by 12ring » October 27th, 2017, 9:21 am
What are you guys doing for a thermometer port? I don’t really want to spend another $75 on a high dollar thermometer for the cook chamber door and I won’t settle for a cheap one. I’ll just use my Maverick. My cook chamber is 1/4” thick. Are you guys drilling a hole and that’s it or is there some type of insert? Thanks.
Re: Thermometer port.
Post by ajfoxy » October 27th, 2017, 4:31 pm
You could use a Silicon High Heat plug with a hole in it for the probes.
Post by Rodcrafter » October 27th, 2017, 9:03 pm
I have just drilled a hole for my Mavericks. The Smoke has larger probes so I will be doing something else soon. I have temp gauges on my smokers so I don’t need the probe for the CC very much any more.
holyp
Post by holyp » October 29th, 2017, 2:05 am
I also drilled a hole in the back, I think it's fine. Managed to get 3 probes in for my cyberQ.
Post by Squiggle » November 4th, 2017, 5:20 am
Yeah, The Wombat just has a hole for the Maverick probes, works fine & no smoke comes out. :beer:
