Can you have to good of a draw?
12ring
Post by 12ring » October 16th, 2017, 10:43 am
I have another thread going on my build but I'll ask this question separately.
Pit info:
My CC chamber is 40" long 19" diameter. FB is 18" long 20" diameter. My opening from FB to CC is 13 3/4" long and 6" wide. A pit calculator called for my FB intake to have 15 1/2" sq inches. I went a littler bigger just to make sure it drafted well. The same calculator called for my 4" stack to be 20" above the CC. A few guys told me to go taller. Some guys recommend 36" and some 24". I split it and went 30". The distance from the top of my fire grate to the bottom of the FB/CC opening is 10 1/4". I have a slightly slanted 6" deflector plate and a 1 1/4" grease bridge.
Question:
Can the pit draw to rapidly? I lit a test fire last night to see where my leaks were and to watch the draft. Door seals leaked slightly but the pit was drafting way better than I expected. I had the intake open all the way. Light blue smoke was spiraling out of the stack and leaves 5-6' above the stack were moving from the pressure going upward. I had a fire bigger than I would be cooking with but what I noticed that concerned me was the flames slightly being drawn into the CC from the FB. I know the fire was to big but I'm wondering if maybe the height from FB grate to the opening isn't enough at 10 1/4" above. (Even though at this point I can't really change that) Or maybe it was doing exactly what it's supposed to do and my fire was just to big. Any info would be appreciated. ImageImageImage
Re: Can you have to good of a draw?
Post by Squiggle » October 16th, 2017, 2:07 pm
I would say that is what you want, if you want to slow it down you can just close off the stack a bit. That's the best part about these units, you can play with it till you get the results you like(& yes DC, that's what she said, lol =)) )
Post by mp4 » October 16th, 2017, 2:21 pm
Your fire is quite a bit more than I think you'll have when you're cooking and I think the draw will slow down with the smaller fire. I think it looks just right myself.
Post by Big T » October 16th, 2017, 7:08 pm
:yth: and like Squiggle said, you can put a baffle on the stack and close it a little bit if you need to.
Post by The Czar » October 16th, 2017, 9:37 pm
I treat my pit like I treat my women...
Squiggle...I’m just saying
Post by Pete Mazz » October 17th, 2017, 4:51 am
Intakes are rarely wide open while cooking
Post by Rodcrafter » October 17th, 2017, 5:15 am
Yep I adjust mine to control temperature and flow.
Post by Squiggle » October 17th, 2017, 1:03 pm
The Czar wrote:I treat my pit like I treat my women...
Oh man, you are so my idol dude! ^:)^
