130 Gallon Smoker
Freiesleben
130 Gallon Smoker
Post by Freiesleben » September 27th, 2017, 2:37 am
Hi All,
I am soon to start my project on a 130 Gallon Smoker. It will be similar to the ones Aaron Franklin builds, but just a smaller scale.
I have been running the calculator as follows: http://feldoncentral.com/bbqcalculator. ... 4.64,84.19
What do people think is a good idea on doors, I have been thinking of two doors like shown on my drawing(measurements on the drawing will be added later). Reason for two doors is to keep temp. loss to a minimum, if I am cooking more than one or two pieces for meat. Where one door will let too much heat out.
The hinges I might want to make of shackles, to get a bit rough look :) Have seen others do that :) But I am not sure if it will be too difficult to bend them. If you have some good ideas let me know :)
Re: 130 Gallon Smoker
Post by ajfoxy » September 27th, 2017, 2:41 am
Looks like you have got the bits to start and I think two doors is fine.
Post by Big T » September 27th, 2017, 6:58 pm
:yth: The only way it would be an issue is if you wanted to cook a whole pig but everything else should fit with no problems.
Post by temurf » September 27th, 2017, 7:04 pm
Looking forward to this build. Ask all the questions that you need to and post lots of pics.
Post by Squiggle » October 5th, 2017, 4:58 am
Looks awesome dude, make sure you run the numbers through the pit calcs at the top of the page, just to make sure it will run smooth. :kewl:
