Wood burner as firebox
randy028
Post by randy028 » January 5th, 2012, 3:36 am
Hello. I have got hold of a wonder coal wood burner for free. It is lined with firebrick and has the grate and shaker for clean out. I plan on using a 500 gal tank for my chamber. Has anybody seen anything like this for a firebox. I could put a damper coming out of the stove to control the amount of heat going into the chamber. I plan on using a reverse flow for my smoke chamber any help appreciated Thanks Randy C
Re: Wood burner as firebox
Post by Frank_Cox » January 5th, 2012, 7:29 am
have never seen one of these used as a firebox. however, I did google them and check them out. it looks like to me it is a wood burning indoor stove. I would be leery to use it since it has been a heating appliance. has it ever actually burned coal? or is that just a part of the name? like i said, never seen one of these.
randy028
Post by randy028 » January 6th, 2012, 4:19 pm
Hello, Thanks for the reply. It has always been used to burn wood in. It is identical to a wonderwood. I was just thinking about it having firebrick in it and being more easy to control
Post by Frank_Cox » January 6th, 2012, 5:49 pm
If it has never had any coal burned in it and if it is big enough for your smoker... it should work fine :kewl:
