How to calculate with a vertical up right
bstory
Post by bstory » June 9th, 2017, 5:15 am
Hey guys it's been a long time. I just need help with fb size. I may buy a smoker project and finish it. It is 24" pipe that is shaped like an L. The main cc is close to 5' long and at the end away from where the fire box would be is 30" tall vertical. Wondering if what to put in the calculator, the total length of pipe as is it were one straight piece.
Re: How to calculate with a vertical up right
Post by Squiggle » June 11th, 2017, 4:25 am
The calculator is designed for offset smokers, I'm not sure what the spec is verticals.
Post by Big T » June 11th, 2017, 8:29 pm
Welcome back bstory, RC could probably help you with that seeing as his big pit is the same shape. I would think that it would work the way you're figuring but I may be wrong.
sjb67
Post by sjb67 » June 11th, 2017, 10:42 pm
Would the height of the vertical cook chamber count as exhaust stack height as well?
Homebuilt offset trailer mount, Big Hat offset vertical, XL BGE and soon a home built double pan gravity feed from smoker builder plans.
Post by Pete Mazz » June 12th, 2017, 4:47 am
Yes
Post by Rodcrafter » June 12th, 2017, 8:48 am
I have been talking to BStory on PM so he has my input
