\\first build 60 gallon compressor tank//
Re: \\first build 60 gallon compressor tank//
Post by Big T » July 10th, 2017, 10:37 pm
You can clean those welds up with grinder and flap disc if you really want to but the main thing is that it's sealed. You should hug your friends neck cause that is a sweet drip pan :kewl:
Post by ajfoxy » July 10th, 2017, 11:49 pm
That is looking really great. And what I found was that once you slap a coat of paint on the welds they seem less "rough". And an absolutely sweet drip tray you got there too.
Post by temurf » July 11th, 2017, 7:47 pm
I'm liking that drip tray.
mbmopar
Post by mbmopar » July 11th, 2017, 9:22 pm
That drip tray is the crux so far....
Sent from my LG-H831 using Tapatalk
Post by Rodcrafter » July 12th, 2017, 6:27 am
That drip pan looks so nice it probably won't fit in the door opening. That is my luck. Is that going to be your baffle plate? it is pretty thin, chances are it won't do a lot of transferring like a thicker BP would. A thin plate will radiate very hot just out the gate (throat opening) and not much at all on the other end. Don't let me stop you, just don't weld it in before you try it.
it might be worth less now, my $0.02 that is
mbmopar
Post by mbmopar » July 12th, 2017, 7:37 am
It just drops into the cooking chamber , fits through the door opening like a glove. I've got some 1/4 plate and a nice peice that falls between 1/8 & 3/16 for the baffle / tuning plates. I'm going to have the drip pan mounted just above the baffle.
Was hoping to dive into it again tonight but woke up to a water leak in our roof so that's on the list.
mbmopar
Post by mbmopar » July 12th, 2017, 3:31 pm
Drip trayImage
mbmopar
Post by mbmopar » July 12th, 2017, 8:52 pm
This afternoon I wire wheeled the interior of the cooking chamber, very messy. The flaky rust had a slight oily quality I assume from the compressor head. A good burn should take care if any residue.
I laid out two rails that will support the tuning plates, and rough cut the plates from 1/4" plate. I'll clean off the edges tomorrow.
I'm curious if drilling a succession of holes is of any benefit to the tuning plates.
Also on tap for tomorrow is making the pass through for the drip tray drain pipe, laying out supports for the drip tray and then supports for the grills. Then cut the baffle for the throat.
Post by temurf » July 12th, 2017, 8:58 pm
:kewl: That is sure looking good.
Post by Rodcrafter » July 15th, 2017, 7:19 am
I'm glad the pan fit through the door. Yes!
I'm trying to get how this is working. I'm not saying it won't just figuring it out. So the drip pan does or doesn't sit on the tuning plates? The tube attached to the drip pan goes through to the bottom of the CC?
mbmopar
Post by mbmopar » August 4th, 2017, 10:04 pm
Yes the drip tube travels downward through the first tuning plate. I don't have any pictures of the setup yet but the tuning plates are set on some 3/16" x 1 " bar running along the length of the CC opening. The plates are about 14x8...four of them.
The drip pan sits about a half inch above that on its own supports.
The grilles rest on their own rails as well.
I am utilizing the air outlet that would typically be on the side of the tank to accept the drain for the drip tray. I have a piece if 1" NPT black pipe the will be welded in the port and will have a ball valve on it. The drip pan tube will slide inside the black pipe.
That drain will be in between the firebox and aluminum underbody box.
mbmopar
Post by mbmopar » August 4th, 2017, 10:07 pm
The smoker is now mobile. There is still some work to do, like building a vent damper for the firebox, raise the woodbox and fix a shelf for a water pan inside the box. Build a shelf frame for the front of the cooking chamber, install door stops for opening the lid, counterweight for the door etc, but it's getting close to done.
The stack raincap is an air cleaner lid from a Super 225 Slant 6 MOPAR, and the FIREDOME emblem is from a DeSoto sedan many years ago.
After the first burn to clean the unit and help lift some of the coating off the tank, it will be repainted with hi-temp black stove paint.
Post by Big T » August 4th, 2017, 10:17 pm
Nice :kewl:
Post by ajfoxy » August 5th, 2017, 3:31 am
Very nice. A really good build.
Post by mp4 » August 5th, 2017, 4:59 am
VERY VERY NICE!!! I like the old car add ons.
Post by Rodcrafter » August 5th, 2017, 2:30 pm
Sweet
jadstar
Post by jadstar » August 5th, 2017, 8:27 pm
That raincap is just AWESOME! Old school MOPAR
Sent from my LG-H811 using Tapatalk
Post by Squiggle » August 8th, 2017, 4:55 am
That looks awesome dude, very nice! :beer:
Post by temurf » August 8th, 2017, 8:44 pm
That sure is looking awesome. :kewl:
Almost time for the Q-View :rulz:
