2nd smoker......finally
Re: 2nd smoker......finally
Post by Squiggle » October 23rd, 2016, 7:00 pm
I made a straight edge out of some 50mm flat bar & clamp it down & I agree with RC, a good dryer makes a difference. :kewl:
Post by ajfoxy » October 24th, 2016, 4:09 am
Air dryer is the way to go for less slag.
And either a straight edge or cnc plasma for ... well straight edges. :beer:
KarateDoc
Post by KarateDoc » October 24th, 2016, 8:17 am
Having an air drier is great but if you are like most and can't afford one, here are some ideas. Drain your air compressor tank after you run it for awhile. This gets the collected moisture out of it. A moisture trap before the plasma cutter can help. I just used a simple inline disposable spray gun filter because I had them. You can get a desiccant drier on eBay for less than $20.00.
Post by Tom_Heath » October 24th, 2016, 8:44 pm
I built one from 2 inch sch 40 pipe. Supply from compressor goes to the center top to bottom. Angled downward at a 45 degree angle fitting welded into the pipe. Fill pipe with steel wool. Bottom of pipe gets a ball valve to drain water and top of pipe gets fitting for air supply back to a tornado dryer. Then a desiccate filter neither of which ever get any moisture. Ever. I will on occasion get condensation in the tank when it's very hot outside.
Post by Rodcrafter » October 24th, 2016, 9:04 pm
That Tom is pretty handy like that.
JohnBFryJr
Post by JohnBFryJr » November 4th, 2016, 3:09 pm
So when I go to put my rack in the firebox should I put it above the vents or next to the vents?
Post by temurf » November 4th, 2016, 3:53 pm
The bottom of my fire grate is slightly above my air intakes. I don't know if it makes a difference or not but I figured that it would force the air through the fire. I don't know anything about the science of it all but it seems to work fine for my pit . I'm sure some of the experts on this site will chime in.
Post by Big T » November 4th, 2016, 7:10 pm
Post by mp4 » November 4th, 2016, 7:40 pm
Yup - put the rack above the vents to get the best combustion.
JohnBFryJr
Post by JohnBFryJr » November 4th, 2016, 8:32 pm
I'll try to post pics tomorrow. Once I mount the fire drawer and fix up the damper I'll be done with the fire box.
Sent from my SAMSUNG-SM-N910A using Tapatalk
Post by Rodcrafter » November 8th, 2016, 7:24 am
JohnBFryJr
Post by JohnBFryJr » November 8th, 2016, 7:43 pm
I only get to work on this beast 30 to 45 minutes a day. Every time I think I'm almost there I think of 5 more things to do.
I'm currently working on the damper. I finally found a 1/2" spring for the 1/2" round stock handle. I have an idea of how it should work. Spring, washers, rod under tension. Coolio.
Next thing I'm researching is latches. I really don't want a piece of flat bar in a notch. I'm also not an engineer. More like redneck trailer park engineer. I am looking for simple cam latches.
Hope all the made sense.
Post by Rodcrafter » November 8th, 2016, 7:48 pm
I get mine from toggleclamps.com
forty_creek
Title: 40 Ways 2 Kansas
Post by forty_creek » November 8th, 2016, 8:29 pm
RC you have the link to the latches Frank made for MACK? There was a video
DRANKIN, SMOKIN and DREAMIN
JohnBFryJr
Post by JohnBFryJr » November 9th, 2016, 7:52 pm
I've never run a firebox this big before. Is 15" from the bottom the fire tray box to the top of the fire box enough height to not melt the top of the firebox? My intakes can be rewelded and moved 3" down but in the grand scheme of things will 3" be a big deal?ImageImage
JohnBFryJr
Post by JohnBFryJr » November 9th, 2016, 7:54 pm
Added the same image twice. Between. Tapatalk, the kids, and my mother's rambling I'm not 100%
JohnBFryJr
Post by JohnBFryJr » November 10th, 2016, 7:56 am
I tacked it all in just to see what it would look like. I think it's fine. My other cooker is a top loader. I can put stumps in that fb.
Post by Rodcrafter » November 10th, 2016, 10:36 am
This is the portion of the thread FC was talking about regarding the latch system Frank made for the Mack.
http://www.smokerbuilder.com/forums/sea ... &start=275
You are doing some nice work!
Post by Frank_Cox » November 10th, 2016, 7:44 pm
Looks great!!!
That's a good one that RC posted but here's a thread I reference often by Blazer....
viewtopic.php?f=87&t=2251
Post by Big T » November 10th, 2016, 8:59 pm
15'' should be fine
Post by temurf » November 10th, 2016, 10:29 pm
:LG: :kewl:
JohnBFryJr
Post by JohnBFryJr » November 12th, 2016, 4:32 pm
The great move. Sweet!
Time for a cold beverage before fishing tonight. I'm stoked that I got my little Shop back
Post by Big T » November 12th, 2016, 5:31 pm
Well that's one way to do it!!
Post by Squiggle » November 13th, 2016, 2:23 am
:LG: :kewl:
Post by Rodcrafter » November 13th, 2016, 9:25 am
It is nice to have large toys to help with heavy lifting
