Rebuilding a Screwed up 200 Gallon Crossflow
SmokinHawgBBQ
BBQ Comp Team Name: Madmikes Smokin Hawg BBQ
KCBS Judge
Always lookin for guys to join the team !
Post by SmokinHawgBBQ » July 3rd, 2016, 9:11 am
I'm rebuilding a 200 gallon trailer mounted smoker another builder made for a guy who lives about 25 miles from my shop, it was built by a guy who's shop is only about 4 miles from mine. The owner has never really gotten to cook on it in 2 years!! The firebox was only 54% of needed, opening between cc and fbox in the center of the tank, door hinges mounted wrong,so no top seal, stack too small,mounted mid tank. he could only use the first 18 inches out of the firebox to cook in. There was so much creosote in the tank I was scared of having a house chimney type fire if I started cutting on it,plus the creosote was like concrete,we coulden't even scrape it with putty knives,so I had the inside of the cc sandblasted, and basically only using the tank itself and cooking grates for the rebuild.
Mike
NEVER MET A PIG I DIDN'T LIKE
SmokinHawgBBQ
KCBS Judge
Re: Rebuilding a Screwed up 200 Gallon Crossflow
Post by SmokinHawgBBQ » July 3rd, 2016, 9:27 am
Started by removing small round firebox,and having tank sandblasted, looks brand new inside now. Only thing done right was tank welded to trailer !! Having a bear of a time cutting it loose to raise it up for the new firebox to clear the ground, had to remove the fender and tire on one side for access to the angle iron welded from the tank to the trailer. the owner supplied the other builder the tank,and trailer for the build.
Mike
Post by Big T » July 3rd, 2016, 12:31 pm
Do you ever rest? This looks like the beginning of a nice cooker.
Post by Rodcrafter » July 3rd, 2016, 6:07 pm
Yeah it does look like you're on the right track
SmokinHawgBBQ
KCBS Judge
Post by SmokinHawgBBQ » July 3rd, 2016, 6:28 pm
Still have the busted leg, so I do the heavy stuff on the weekends when my buddy who cooks the comps with me is at the shop. we cut the tank loose today,had to remove the fender and tire in the tank side to get to mounts the other guy put in, we set it on 8 inch blocks to hold it at the new height while we make new mounts, I already made the new firebox the right size,so it should be easy to finish it up.
Mike
Post by Dirtytires » July 4th, 2016, 12:02 am
Sounds like somebody spent a lot of time to build a poorly designed smoker.
SmokinHawgBBQ
KCBS Judge
Post by SmokinHawgBBQ » July 4th, 2016, 11:07 am
Dirtytires wrote:Sounds like somebody spent a lot of time to build a poorly designed smoker.
Worst part was the owner supplied the tank and trailer,and the guy still charged him 2 Grand to build it, when it didn't cook the guy just kept telling him he wasen't making big enough fires. 2 years of frustration later we are basically starting over on it.
Mike
Post by Squiggle » July 5th, 2016, 3:45 am
Looks like it will be an awesome rebuild, can't wait! :beer:
SmokinHawgBBQ
KCBS Judge
Post by SmokinHawgBBQ » July 5th, 2016, 11:23 am
Yesterday my buddy was off for the 4th,so we went over the shop for a couple hours and got the tank in position for the new mounts,cut the old stack off,and cut the back of the trailer for the new firebox. it only had a 6 inch wide shelf across the front,and the crooked chain handle kept it from being used, I'm cutting it off to add 2 spring handles to match the firebox handle, I'll make a swing down shelf extension off the existing 6 inch wide shelf.
Mike
Post by Rodcrafter » July 5th, 2016, 2:58 pm
:beer:
SmokinHawgBBQ
KCBS Judge
Post by SmokinHawgBBQ » September 23rd, 2017, 9:59 pm
Finally can post rest of build pics !!
Post by Big T » September 23rd, 2017, 10:40 pm
It turned out great :kewl:
Post by ajfoxy » September 24th, 2017, 1:49 am
:yth: Nice
Post by Pete Mazz » September 24th, 2017, 5:26 am
:kewl:
Post by mp4 » September 24th, 2017, 7:49 am
AWESOMENESS!
Post by Rodcrafter » September 24th, 2017, 7:51 am
Very nice! The air vents look like butterflies.
Post by Squiggle » September 24th, 2017, 9:05 pm
Lol, they totally do!
Nice work dude, looks awesome & im sure it will perform now. :beer:
Post by temurf » September 27th, 2017, 8:18 pm
:kewl: Great job there Mike.
That owner sure got hosed by the other "builder".
:points: Good to know that you got it fixed up.
Hope you get to partake in the first Q.
KarateDoc
Post by KarateDoc » September 28th, 2017, 7:08 am
Great job! Is that smoke stack removable? Did you fire it up and test it?
