• Advertisement
Photobucket
UDS wind problem
UDS wind problem
Postby Rick » April 15th, 2012, 5:48 pm
Since I don't have a UDS I need to ask you guys that do for some info about how wind is effecting them...
Do you think the wind is stripping heat off the skin? (running cold on a windy day)
- or -
Is the wind messing with the airflow through the drum? (running hot on a windy day)
- or -
Is it a combination of both of these and if so which do you think is mostly to blame?
I might be smoking my socks but after 2 years of fooling with fires/cooking chambers/draft designs and Nebraska wind, I THINK I can fix most of this problem if I had some input ...
So what do you say? - let's rid the world of cantankerous UDS's :)
Smokerbuilders do it slow to make it last ... ~O)
Rick
BBQ Comp Team Name: Edna's Kids
Re: UDS wind problem
Postby Frank_Cox » April 15th, 2012, 6:57 pm
the problem is the same as with any smoker. the wind blows into the firebox/ drum and causes temps to either skyrocket or it will draft out the other air inlet instead of the stack. usually fixed by rotating the drum a little :grillin:
Postby dcman (The Czar) » April 15th, 2012, 7:00 pm
:yth: .....or do it what I do and cook in a car port so the wind isn't an issue.... :grillin:
I wear big women's under all the time......so much room for me and Alleyrat.....
dcman (The Czar)
Postby Smokeone » April 15th, 2012, 7:48 pm
I agree with Frank.
Of course the Mrs refers to this as Windy Hill Acres, so if you can help fix that I would be appreciative!
BBQ Comp Team Name: Smokerbuilder.com - Competition BBQ Team
Postby Frank_Cox » April 15th, 2012, 8:04 pm
dcman wrote::yth: .....or do it what I do and cook in a car port so the wind isn't an issue.... :grillin:
what a resourceful photo czar we have.... :wsm:
Postby Rick » April 15th, 2012, 8:07 pm
Okay - I'll try posting a drawing here .... stay tuned ... :)
Rick
Postby maccas66 » April 16th, 2012, 1:36 am
Roger that Rick!...... :help: ...................don`t carports only have roofs! :-s
" I`m so hungry, I`m farting fresh air!"
maccas66
Title: Aussourian Plumber
Postby Rick » April 16th, 2012, 6:35 am
I thought so mac but maybe DC had the assembly instructions turned wrong so it's a wall instead of a roof now ... =))
Rick
Postby dcman (The Czar) » April 16th, 2012, 7:02 am
Not my carport.....it was walls about 4 foot high then it is all screened in....my bad.... #-o .....it used to be a carport until I screened and walled it in.... :huh: ....but its not a garage really....so what would you call it.... :-w
dcman (The Czar)
Postby Frank_Cox » April 16th, 2012, 7:09 am
I would call it the garaport
Next
  • Advertisement
Get our toolbar!
Return to UDS Smokers
Who is online
Users browsing this forum: No registered users and 1 guest
Photobucket
cron
