Rack bolts
Buckscent
Rack bolts
Post by Buckscent » July 16th, 2018, 4:26 pm
What is best or what is everyone using for bolts for the racks to sit on? Seems the only SS hex bolts I can fine are not threaded all the way. Been looking at 1/4-20 3”
Re: Rack bolts
Post by Dirtytires » July 16th, 2018, 9:35 pm
What are you building?
Sounds like a uds. Stainless really isn’t necessary, just fights off rust on the outside a bit...the inside is still gonna be black after a few smokes. Either weld some tabs inside or the above bolts should work just fine.
Re: Rack bolts
Post by Rodcrafter » July 17th, 2018, 7:51 am
1”x1/4”x20 works fine
bswisher
Re: Rack bolts
Post by bswisher » August 2nd, 2018, 9:14 am
I recommend using the cheap shelf brackets from Lowes/HD etc. Just tack weld 3 of them to the inside of the drum. The actual shelf supports can be cut down to about 1 1/2-2 inches long and allows you to adjust the rack height as needed. Also makes it very easy to add additional racks. Not a great picture but you can see how i did it on mine.
Current Smokers, Brinkman ECB, Masterbuilt 30 Analog, SmokeHollow Pro44, Home Built 60gal RF, UDS
Nothing wrong with being stupid as long as you know you're stupid, it's when you're stupid and don't know it that you become dangerous
