Soybean paint
- Big Time SmokerBuilder
Soybean paint
Any chance anybody is ever seen a soy bean barrier the lady that I got the drum said it's not paint it's a soy Bean barrier that's food grade. Apparently it's FDA approved for food to touch because it's not a paint. Any recommendations before either grinding it off or burn it off
- Big T
- Moderator
- Title: Go Getter
Re: Soybean paint
I'm not sure what it was called but it looks similar to the coating in the last food grade drums that I bought. I burned them out real good and then scrubbed them with comet and a hard bristle brush.
- The Czar
- Founder
- Title: Spam Hammerer
- BBQ Comp Team Name: Team SmokerBuilder- Competition BBQ Team
I'm Certifiable - Location: Missouri
Re: Soybean paint
Burn it...scrub it...season it...enjoy it
- Needs more Steel
Re: Soybean paint
It needs to go,. The orange layer is the dreaded barrier. You need to burn it or sand blast it out. Contrary to what you may think, barrels that have not had food in them are better, then barrels that have had contained food.
- Rodcrafter
- Moderator
- Title: Member
Re: Soybean paint
Burn it and clean it with comet after. I hear that's the best way to deal with those.
Re: Soybean paint
Real time it's happening
Re: Soybean paint
Getting closer few more turns and all will be cooked
- Big T
- Moderator
- Title: Go Getter
- ajfoxy
- Expert
- Title: Neophyte Smoker Bldr
Re: Soybean paint
For a few seconds it looked like you had a whole tree parked in that drum...
Re: Soybean paint
Getting closer
- Just Got in trouble for buying tools
Re: Soybean paint
Looks good.
I wish i lived in a more rural area like that to burn my drum instead of having to pay someone to sandblast.
Re: Soybean paint
[quote="richy20"]I wish i lived in a more rural area like that to burn my drum./quote]
Careful what you wish for my lid no longer fits on the drum
Re: Soybean paint
Not sure what todo
- ajfoxy
- Expert
Re: Soybean paint
Bugger.
You could use this unfortunate incident to move up in the UDS world and use a Webber kettle lid. Some fit nicely others need a rim of steel welded on the inside of the drum and sticking out a bit.
- Big T
- Moderator
- Title: Go Getter
Re: Soybean paint
Re: Soybean paint
Show of hands. looking for a little help. I have 2 ideas. Problem is when i burned the berral out the top of the drum got smaller. Lid is way to tight to drop down for a good fit.
1. Cut the lip of the berral in a few spots, opening it up just enough for the lid to fit down tight on the drum. then weld it back up and grind it down. I am leaning this way. should be easy fix.
2 Go buy some sheet metal and build a new lid. Thinking 1/4 should be heavy enough. lol may be even insulate the lid while i am at it.
Re: Soybean paint
air inlets are done
- Big T
- Moderator
- Title: Go Getter
Re: Soybean paint
I would go with the easiest method. I know that was a big help.. lol. Do you think that you can stretch it back out to fit the lid or is it going to turn in to a dog chasing its tail ? I can't tell how bad it is from the picture but I know that it's hard to make a perfect circle after it has deformed and the lid will need to fit pretty snug.
- ajfoxy
- Expert
Re: Soybean paint
Jeez 1/4 for the lid. Put a hinge on it then as it will be very heavy. I generally make my flat lids out of 1.6 mm sheet. With a 2mm x 15mm steel strip around the edge. Not had one warp yet. A ring roller of sorts is an essential bit of kit for this method though. You can do it manually but it takes awhile to get right.... a cnc plasma table is also a handy thing, but it can be done manually.
Or else you can look around for a Webber (or similar) kettle lid and use that. Benefit of webber lid is that is you can have two grids with meat on as the top one will fit nicely inside the webber dome.
A pic of one I started making awhile ago (hence the rust) and not used as everyone wants a webber type dome lid.
Re: Soybean paint
I have been using my UDS, Its crazy how little fuel this little thing uses. Very happy so far. Thinking I need to build a new one with a better lid.
- Needs more Steel
Re: Soybean paint
Look for a Weber grill with lid on Craigslist. Sometimes you can get lucky and find one for free or near free. Weber lids are the way to go on a UDS. Gives you much more room
- Rodcrafter
- Moderator
- Title: Member
Re: Soybean paint
I don’t know but you might be able to buy a lid at a local drum dealer. I buy mine new unlined with open top. Then I use the ring on the top to make my Weber lid fit the drum.
Re: Soybean paint
I have cooked a lot of food on this little drum so far Still impresses me each time.
- McBroom
- Expert
- Title: Retired U.S.Marine
Re: Soybean paint
I agreeajfoxy wrote:Bugger.
I Love My 2018 RAM 2500HD 4x4 Off Road 6.4L. USMC (ret)
