How I make a dome lid for a open head drum UDS.
Post by Frank_Cox » October 13th, 2012, 1:00 pm
Dome lid on the cheap. Place an ad on Craig's list or a classifieds site. The ad should read "looking to buy weber bbq grills in any condition"
You will get people calling you with kettles missing legs, missing grates and handles, etc. I try to offer them $15.00 for these or $40.00 in prime condition.
Top lids are easy to use. In this post I will use a kettle bottom.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
Re: How I make a dome lid for a open head drum UDS.
Post by Frank_Cox » October 13th, 2012, 1:01 pm
Post by Frank_Cox » October 13th, 2012, 1:04 pm
Clean the lid very good I use purple power or greased lightning
Post by Frank_Cox » October 13th, 2012, 1:24 pm
You won't be able to get it perfect, but it'll come out pretty clean. Next thing remove the bolts that hold on the air inlets. I like to replace the bolts and make them look nice. then take a grinder and grind the porcelain along the rim down so you can get to the plain metal
Post by Frank_Cox » October 13th, 2012, 1:30 pm
Don't grind on it too much. Only grind it long enough to were you see bare metal pop through. The metal on this lip is very very thin so you only want to grind enough to remove porcelain try not to dig into the metal.
Post by Frank_Cox » October 13th, 2012, 1:38 pm
I like to remove the leg attachment holders but if your Tom_Heath you can leave them on there and make springy pigs and chickens and stuff hang off of them. I like to use a cutting wheel to get the main part of the holder off and then use a flap disc to remove a little ears that are spot welded on
Post by Frank_Cox » October 13th, 2012, 1:40 pm
Post by Frank_Cox » October 13th, 2012, 1:42 pm
Post by Frank_Cox » October 13th, 2012, 2:10 pm
Grind the paint of the rim of a flat lid
Post by Frank_Cox » October 13th, 2012, 2:18 pm
Using short 1-2 second bursts, stitch weld about every 6" or so. I keep most of the heat on the dome so I don't burn through tree flat lid.
Post by Frank_Cox » October 13th, 2012, 2:21 pm
Using a cutting wheel cut the inside of the flat lid out
Post by Frank_Cox » October 13th, 2012, 2:28 pm
Last thing after we paint is to seal around the welds. Next I put on the handles them paint the lid.
Post by Frank_Cox » October 13th, 2012, 2:40 pm
Got the holes drilled for the handles. Hit the bare metal with some primer then wet sand the whole thing with 400 grit and paint it
SmokinFF
Post by SmokinFF » October 13th, 2012, 7:59 pm
Thanks Frank. I picked up a kettle but wasn't sure how I was gonna make it work.
Post by Frank_Cox » October 13th, 2012, 8:17 pm
I will paint and finish it Monday. Didn't feel like cleaning the paint gun tonight lol
Post by Rodcrafter » October 14th, 2012, 8:16 am
Thanks Frank, I'm going to use some of this good stuff to change the lid on my buddies UDS style rig. He made one out of a air tank, the lid is very heavy making it hard for him to use. This should do the trick, I was going to make some counter weighted devise to do the job useing the same parts but I think this is nicer.
:LG: :points: :points: :points:
Post by Frank_Cox » October 14th, 2012, 9:25 am
Thanks RodCrafter! Is the lid on your buddies rig hinged? I have been looking for some ideas for a good spring loaded hinge design for heavy round lids.
Post by Rodcrafter » October 15th, 2012, 7:19 am
No, that's the problem it isn't he has to lift it on and off. I think I could square it off using some angle iron to put hinges on it. But he has a piece of flat plate he rolled and put on the inside to make it more sealed, so the lid has to go straight down. So of course the hinges would have to get pretty involved to make that happen. It looks like your plan is best.
Post by Frank_Cox » October 15th, 2012, 8:24 am
Post by Rodcrafter » October 15th, 2012, 2:00 pm
That's too funny Frank,
That is almost exactly what I was goint to do with the lid on my buddy's cooker. I had already told him the details base, post, lever and swivel. But I thought it was a bit much, for him to have to move around from time to time. He said "your the rigger", so I thought I would do a little.
But I still like the weber idea better.
Post by Frank_Cox » October 15th, 2012, 2:42 pm
First coat of paint
Post by The Czar » October 15th, 2012, 4:42 pm
I hope you didn't get paint on the asphalt....the clean up guy is going to be upset.... :LG:
Post by Smokeone » October 15th, 2012, 4:44 pm
Gotta keep the clean up guy happy! :hissy:
You know thats not bad he had the first coat on by 242 pm. =))
Post by The Czar » October 15th, 2012, 4:54 pm
That's funny.....
Post by Frank_Cox » October 15th, 2012, 6:13 pm
Thanks guy's! gonna wrap it up tomorrow!
