Reverse flow hybrid smoker: vertical smoking chamber question.
Re: Reverse flow hybrid smoker: vertical smoking chamber question.
Post by Big T » September 23rd, 2018, 2:53 pm
That's what I was expecting to see, those bright red initials! :kewl:
Post by ajfoxy » September 23rd, 2018, 4:36 pm
Yes, now those letters pop out. The whole unit looks good. Nice :kewl:
AndrewPalmer71
Title: SmokinAddict
Post by AndrewPalmer71 » September 23rd, 2018, 6:53 pm
Thanks fellas!
Post by Pete Mazz » September 24th, 2018, 5:30 am
:beer: :beer: :beer: :LG: :LG: :LG: :beer: :beer: :beer:
JRINNE
Post by JRINNE » September 24th, 2018, 5:11 pm
Very nice indeed!
Post by The Czar » September 24th, 2018, 10:48 pm
I’m liking it
Post by Dirtytires » September 25th, 2018, 12:15 am
Great job...looks fantastic.
Forgive me if this has been mentioned as I could have missed it but what did you decide on for paint? I see you sprayed it and assume you used a hvlp gun? What did you use for a primer?
AndrewPalmer71
Title: SmokinAddict
Post by AndrewPalmer71 » September 25th, 2018, 5:50 am
Thanks guys! No problem DT. I actually went over budget on paint and primer. On the black parts, For Primer I used PPG 1027 high heat and top coated with PPG 500 v.
On the red parts I used rustoleum high heat primer and high heat topcoat.
The blue part is duplicolor caliper paint.
I sprayed the PPG with a speedway siphon feed sprayer 2.0 nozzle. It can be purchased through home depot and is the best cheap gun I've ever used.
Post by Dirtytires » September 25th, 2018, 10:50 am
Thanks for the info....having trouble deciding on paint. So many options and many of the high heat coatings want a heat cure at 400 degrees.
I’ve got a really nice hvlp rig that I picked up a number of years ago. I’ve only used it a few times as most of my projects are either too small to mess with the gun (so I rattle can it) or I’ve gone with powder coat finishes. However, it’s time to break it out again and see what damage I can do on my smoker.
bstory
Post by bstory » September 25th, 2018, 4:23 pm
Man, you have done a marvelous job on this cooker. Very nice.
Post by Rodcrafter » September 29th, 2018, 9:25 pm
Very nice work!
AndrewPalmer71
Title: SmokinAddict
Post by AndrewPalmer71 » September 30th, 2018, 9:09 am
Thanks RC, put a pork shoulder on this morning. She's running like a champ. The stack opposite the fb is wide open in this pic, but you can barely see the smoke. ImageImageImage
Post by towtruck » September 30th, 2018, 10:42 am
Looks good but that little hunk of meat looks lonely in that big ol' box. =))
Post by ajfoxy » September 30th, 2018, 4:01 pm
:yth: definitely needs a few companions to share the journey.
Post by Big T » September 30th, 2018, 5:36 pm
Did you season everything real good ? It'll keep it from getting all rusty on the inside.
AndrewPalmer71
Title: SmokinAddict
Post by AndrewPalmer71 » September 30th, 2018, 5:46 pm
Oops. Not yet, how should I? A generous helping of cooking oil slathered over the chamber? She's still running at this minute, so it would not be a problem.
Post by Big T » September 30th, 2018, 8:41 pm
Sorry I didn't see this earlier but you can do it your next cook. I like to spray everything a light coat of cooking oil and heat it up for a little bit and then back it down to cooking range and throw something greasy on there. Don't coat it too thick with cooking oil or it just gets messy.
Post by Dirtytires » September 30th, 2018, 11:03 pm
Ditto that....THIN spray of PAM and I like to wipe/smooth it out with a sprayed paper towel. Just keeps the puddles from getting messy. When you heat it up, probably gonna drip a bit so do next cook in the grass. Hit your racks and everything on the inside.
Post by ajfoxy » September 30th, 2018, 11:59 pm
And if you draw a smiley face in the oil, then season... you'll have a smiley face to greet you next time you cook... :D
Post by Dirtytires » October 1st, 2018, 10:54 pm
You need help, AJ....lol
AndrewPalmer71
Title: SmokinAddict
Post by AndrewPalmer71 » October 21st, 2018, 12:55 pm
*Sunday cook* been experimenting with this rig since I completed it. I can run it traditional offset with even temps across all 3 chambers, or reverse flow with only the middle chamber, or reverse flow with the middle chamber and left vertical. I also cut a port on top of the firebox in case I want to run the left vertical solo.
Today I cooked whole chickens spatchcocked using the reverse flow middle chamber, and cooked a roast in the left vertical. I heated the vertical with the port from the cook chamber, which works better than the port on top of the firebox. So unless I am cooking in the left vertical exclusively, I will probably use the cook chamber port to heat the left vertical.
I included the thermometer pics for info on which chambers I am using and those I am not. The left vertical is about 30 degrees cooler than the middle chamber. Which is perfect for chicken and roast.
This thing cooks like a charm!! Enjoy the pics. Will update with Q view once complete. ImageImageImageImageImageImage
Post by Big T » October 21st, 2018, 5:05 pm
:kewl:
Post by ajfoxy » October 21st, 2018, 5:07 pm
Very nice :kewl:
