Mack™
Re: Mack
Post by Dirtytires » February 27th, 2018, 11:23 am
I gotta buy a new printer.....lol
Mack
Post by Frank_Cox » February 27th, 2018, 12:11 pm
Hahaha right!
By the way, 2 other sizes should be coming out later this year. Bigger one and also a smaller one.
Re: Mack
Post by The Czar » February 27th, 2018, 8:22 pm
And more ink
MattJ
Re: Mack™
Post by MattJ » May 2nd, 2018, 4:40 pm
What size trailer is the Mack on?
Re: Mack™
Post by Frank_Cox » May 2nd, 2018, 7:05 pm
4 x 10
hutcho
Re: Mack™
Post by hutcho » May 7th, 2018, 9:50 am
Any updates on the trailer plans and smaller version? Mostly just posting so I get updates when they release :)
Re: Mack™
Post by Big T » May 7th, 2018, 7:36 pm
The plans are available now. You can get them at smokerplans.net
Re: Mack™
Post by Frank_Cox » May 7th, 2018, 7:50 pm
hutcho wrote:Any updates on the trailer plans and smaller version? Mostly just posting so I get updates when they release :)
Yep, as BigT said the 24x24x48 ones are available now. Metric version will be released this month. also we have a smaller version and a larger version on the drawing board. Hope to get them done before the end of the year.
:beer: :beer:
hutcho
Re: Mack™
Post by hutcho » May 9th, 2018, 7:48 pm
Do you have a completed picture of Mack? Trying to show my wife what's fixing to happen around here and the build pictures aren't doing it for her lol!
Re: Mack™
Post by Dirtytires » May 9th, 2018, 10:12 pm
Yea....what happened to all your pictures?
hutcho
Re: Mack™
Post by hutcho » May 10th, 2018, 7:23 am
They are all dead on Tapatalk. I found some with a Google search.
Re: Mack™
Post by Frank_Cox » May 14th, 2018, 6:51 pm
oh man, we just added SSL security certificate. now the tapatalk images are being blocked. that's a bad deal. I will start working on it right now...
:headwall: :headwall: :headwall: :jocomp: :jocomp: :jocomp: :jocomp2: :jocomp2: :jocomp2:
Re: Mack™
Post by Frank_Cox » May 17th, 2018, 6:46 am
Wow! Their back!
Re: Mack™
Post by Dirtytires » May 25th, 2018, 12:21 am
Great job....thanks.
Ive learned a lot with that build and im sure many others have also.
Gracin
Re: Mack™
Post by Gracin » July 5th, 2018, 1:38 pm
I've been eyeballing this build for quite a while now. Congrats on getting the plans released, I love the design. I know you're planning on releasing a smaller as well as a larger version later this year. I'm actually planning on building a smoker this summer to start doing more vendor/cater events. I think this design is just what I'm looking for, but I'm wanting to go larger. The CC with have 3 racks with a 4th available for shorter foods. The measurements I'm looking at are 60"x30"x30" for the CC and 30"x30"x30" for the FB.
After plugging my numbers into the calculator, I'm having trouble figuring out the opening measurement from the FB to the CC, which I believe you guys call the 'throat'. The calculator comes up with 216in^2 . Is there a good way to lay this out for the cut measurements? Also, I'm not really sure if how high the baffle plate needs to be off the bottom of the CC, or what the opening at the end of the baffle needs to be.
Any help would be greatly appreciated. Thanks!
Re: Mack™
Post by Big T » July 5th, 2018, 8:06 pm
Welcome aboard! You should start a thread in the questions forum and we'll help you out all that we can.
Re: Mack™
Post by The Czar » July 6th, 2018, 5:01 pm
Mack should have a cut sheet available to buy
rfuilrez
Re: Mack™
Post by rfuilrez » August 10th, 2018, 1:46 pm
I’m looking to build a smoker capable of much more capacity than I currently have. My current pit is a Pit Barrel Cooker. I’ve got a HeaterMeter on it and I’m happy with it, but it’s gotten a little small for some of my usage cases. I’m trying to decide between The Mack and one of the gravity feed smokers.
I like the ability to just set it and forget it with my PBC. Once the HeaterMeter has control of it, I can basically let her sit until the meat hits temperature. How often would I have to mess around with The Mack? I know it’s a stick burner, and I would have to add wood and stoke the fire sometimes. I’ve never used a stick burner but wouldn’t mind getting into one. Most of my cooks aren’t overnight though. I could just run the PBC when I want to do a brisket or butt for myself overnight.
I guess I’m asking for a little advice on the pros / cons of both. Mainly how much would I need to babysit this. Would it be able to be left alone for 3-4hrs? I think I would prefer a wood fired pit, flavor wise, but I’m not sure if it means having to tend to it every 30mins-1hr.
I’m waiting for the new plans Frank is getting ready to publish, but I’m thinking if it’s as big as the DP GF it’s going to be way more smoker than I need. My biggest cooks so far have been like 7 whole pork bellies for bacon. I had to do it in 3-4 separate cooks on the PBC. If I could get 10whole pork bellies or 5-6 briskets at once I would be happy size wise.
Thanks in advance.
Re: Mack™
Post by Frank_Cox » August 10th, 2018, 2:03 pm
Good questions.
On any reverse flow smoker you will need to tend the fire on a frequent basis. most of them are 45 minutes or so. especially a pit like Mack™.
The Gravity Feed smokers do not require tending a fire. mostly just clean the pit after each cook and your ready to go next time.
Re: Mack™
Post by Dirtytires » August 10th, 2018, 4:46 pm
One thing to add....the controllers don't work too well (if at all) with a reverse flow setup. If you want a stick burner, you are going to tend it every 45 min on every cook. The mini/dp will run great with a controller.
Maybe the Mack for big cooks then a uds for your occasional overnight cooks?
Re: Mack™
Post by Chromeski » August 10th, 2018, 6:15 pm
I think best bet would be to build the large and small mack plus a gravity feed cooker or two. Best of both worlds
hutcho
Re: Mack™
Post by hutcho » September 26th, 2018, 9:42 am
Any updates on the mini Mack plans? Kinda holding out for those ;)
Re: Mack™
Post by Frank_Cox » September 26th, 2018, 10:47 am
Not yet, we are still several projects behind. I do not expect to see those until closer to spring. could be sooner than that but I need to stop being so optimistic... bites me in the a$$ everytime...
:BDHorse: :BDHorse:
hutcho
Re: Mack™
Post by hutcho » September 26th, 2018, 12:04 pm
Frank_Cox wrote:Not yet, we are still several projects behind. I do not expect to see those until closer to spring. could be sooner than that but I need to stop being so optimistic... bites me in the a$$ everytime...
:BDHorse: :BDHorse:
That's a ways out! May end up buying the big ones and scaling them down myself. Then again may not have the $$ to build one until spring anyway lol! Thanks for the updates Frank
Re: Mack™
Post by Frank_Cox » September 26th, 2018, 8:13 pm
Here ya go fellers... The long awaited Metric version of Mack! This product includes the CNC files in metric...
Click here : Metric Mack™ Reverse Flow Smoker 610x610x1220
