Hello, Im planning a reverse flow trailer build using a lang model 60 with warmer as a reference. 24" diameter pipe, 5' long with a 24" dia. by 24" long firebox. My questions are, how big does the hole between the firebox and the chamber need to be? How much clearance can there be between the baffle and the cooking grate? How big does the gap between the end of the baffle and the chamber need to be?
I plan on using 4" pipe for the stack, will 4' be long enough? How big does the hole between the horizontal chamber and the warmer/vertical smoker need to be? Can this hole be at approximately grate level in the main chamber without causing (stagnant?) problems? Thanks for any and all help.
