High build primers
Diggerg
High build primers
Post by Diggerg » March 11th, 2019, 3:39 pm
So once I've built my GF I plan on blasting it at work in our blast room. I'll be usng recycled iron silicate so it'll be clean but with a little surface profile. Has anyone used a high build automotive primer before basecoatng.
Overspray
Re: High build primers
Post by Overspray » March 11th, 2019, 9:04 pm
I’d recommend using PPG CRE-921 (Black) or CRE-321 (Gray). These epoxy primers are specified to go over blasted metal and adhere excellent. They’re thick and can easily be surfaced for basecoat. They can also handle up to 300deg if you’re using it on an insulated smoker.
Post by Dirtytires » March 12th, 2019, 12:16 am
Bump——
Sorry but I’m still in the same boat. Once primered, do you have a recommendation on topcoat? I’m fine with traditional black.
Diggerg
Post by Diggerg » March 12th, 2019, 2:59 am
Thanks. Yes it's an insulated smoker. I plan on using this as a topcoat.
Ebay item 192344686451 with a clear coat over the top. Would you recommend black or gray as the primer for this type of colour?
Overspray
Post by Overspray » March 12th, 2019, 4:47 am
Dirtytires - if youre fine with traditional black, there’s probably cheaper ways to go. If you’d want to use that epoxy primer, any automotive basecoat/clearcoat would works.
Diggerg - that’s a nice looking color. I’d go with the black primer (it’s more of a dark gray anyways).
Diggerg
Post by Diggerg » March 12th, 2019, 5:16 am
I like it. It looks black from a distance but has that wow up close
Diggerg
Post by Diggerg » March 24th, 2019, 12:20 pm
I'm in the UK and can't seem to get PPG paint. Would a standard 2 pack high build do?
Overspray
Post by Overspray » March 25th, 2019, 6:59 am
Usually, no. They’re generally NOT rated for direct to metal.
NEXA is PPG’s euro line. They have two primers, one of which I have actually sprayed.
565-3800 is a general purpose 2k primer, says it’s direct to metal. It only shows prep for steel as sanded with 80-150grit paper, not blasted.
P580-4501(White)/4505(Gray)/4510(Beige) is a high build 2k epoxy primer rated for application over blasted metal. However, I’m unsure if it can be purchased in gallons.
Neither of these had temp ratings on their data sheets, but I’d assume both would be fine on an insulated smoker. Hope this helps!
Post by Chromeski » March 26th, 2019, 3:32 am
I think around the firebox exceeds 300F. You may consider installing a piece of aluminum diamond plate around that area
Diggerg
Post by Diggerg » March 26th, 2019, 9:52 am
We use Sherwin Williams L425 2k epoxy primer at work but I can't find anything about temp resistance
Overspray
Post by Overspray » March 26th, 2019, 10:53 am
You could also just tape off a few inches (cm?) from the firebox and just use high temp paint in that area. I’d probably do that even if you’re going to cover it in aluminum.
Diggerg
Post by Diggerg » March 26th, 2019, 10:55 am
Sounds like a good idea. I plan on putting an aluminium surround on.
