Homemade gf mini temperature controller
Re: Homemade gf mini temperature controller
Post by temurf » March 9th, 2017, 10:38 pm
That is sweet Weldun. Very sweet
bigbook
BBQ Comp Team Name: smoker done <nobody beats our meat>
Post by bigbook » March 15th, 2017, 9:33 am
You can always use the extra computer power cords piled up in closet instead of Her stuff. .. less trouble down the road .....
Sent from my XT1585 using Tapatalk
bigbook
Post by bigbook » March 15th, 2017, 9:41 am
Pid control from eBay with a solid state relay costs around 18 bucks , fan salvaged from dead comp. only problem is comp fan is 24 volts. Low voltage transformer 12$ for said fan electric conduit box ten bucks. Flex hose to cooker from control ¿???
Extension cord. Not from wife's stuff!! Five bucks
All in all. One quarter the cost of a guru if that much
Post by Weldun » March 15th, 2017, 4:10 pm
I'm right there with you bigbook, the homemade route my not be for everyone since they lack some of the bells and whistles that some of the nice ones out there offer, but if you can get by with basic,dependable and accurate temperature control they are hard to beat.
SAFETYHARBORREDNECK
Title: ChefBoyareyoukidding
Post by SAFETYHARBORREDNECK » March 20th, 2017, 5:39 am
OK.So I'm putting a parts list together.
Where did you say we could acquire a 120v power cord,LOL.
And how did you pressurize the box?
Sent from my 5054N using Tapatalk
NEVER trust a skinny cook!
Post by Weldun » March 20th, 2017, 5:40 pm
Really all "pressurized box" amounts to is a sealed box that has two openings, one is attached to the inlet side of blower and the other attached to the tube that goes to the air inlet valve on smoker. When the blower comes on it draws air into the box and is discharged out the path of least resistance which happens to be the tube. If you look at some of the previously post pics you'll see a round hole on the bottom of box, if you look closely you'll see the squirrel cage of the blower.
TurboMike
Title: welder and fab
Post by TurboMike » April 15th, 2017, 6:39 am
Where did the fan come from ? You did great!
No matter how many times i cut, its still to short!! :-w
Post by Weldun » April 15th, 2017, 7:18 pm
It's a 75x75x30mm 12volt DC brushless fan I paid less than $4.00 for if you do a search you'll have more places to buy than you need. Thanks for the compliment I've been very pleased with how the controller has worked.
Cole
Post by Cole » November 18th, 2017, 8:35 am
Weldun - Wondering how the connections are holding up that you added thru the side walls? Also, might you have a link to the controller you purchased? Thanks, Cole
Post by Weldun » November 18th, 2017, 10:46 am
Cole wrote:Weldun - Wondering how the connections are holding up that you added thru the side walls? Also, might you have a link to the controller you purchased? Thanks, Cole
The connections have held up great as far as a link for the controller, I looked and where I purchased from no longer has them. However there are many other places that have them if you search " willhi wd7016d" you should find plenty of options, they are available in 12,110 or 220 volt. I used the 110 volt version. Hope this helps
Post by Weldun » November 18th, 2017, 10:49 am
The connections have held up great as far as a link for the controller, I looked and where I purchased from no longer has them. However there are many other places that have them if you search " willhi wd7016d" you should find plenty of options, they are available in 12,,24,110, or 220 volt. I used the 110 volt version. Hope this helps
Post by Weldun » November 18th, 2017, 10:53 am
Cole
Post by Cole » November 18th, 2017, 11:04 am
Thanks!
